Originally Posted by lammydi
It took about 1.5 hour because I didn't have the right tool. You need the long tool to reach up and inside the trunk.
About the 20" rims. I used to have a little vibration when I applied the brake. But I fixed that with the Hub Centric Rings. Do a search on Hub Centric Rings, you'll see my write up.
If the hub centric rings doesn't fix it then it could be balance and/or your rotor is warp.
Did you use the torque wrench to tighten your lug nuts. Don't trust anyone else but yourself to tighten the lug nuts. The correct setting for our Camry is 77
Let me know if you have any other questions. There are lot of information on this forum, the search button is your friend so use it. Then ask more questions after you do your reading.
Wow, thanks a bunch for the tippers, you da man
