I'm not an expert and I'm probably in the minority but I've been driving cars since before disc brakes became common. I simply won't get them turned anymore. Seems they over-heat them which removes the temper and then they warp the 1st time they get wet or they turn them untrue to start with. I just replace the pads after a light sanding of the rotor and replace the rotors if and when they cause a problem. JMHO (BTW, I 2nd the problem with them over-tightening the nuts. I watch them and remind them of the correct torque value.)
