good job man, seriously, it's barely noticeable, your cut lines. definitely wouldn't waste money on an se bumper you did a great job. A suggestion for you, if the cut lines/gaps bother you, silicone around the fog light from the inside of the bumper so you won't notice gaps.
Me i was fortunate to have the japanese bumper and my fog light holes were pre-made with pop off covers. I still used the kit wiring and saved my money from buying the turn signal stalk. Since I have my fogs on always when my low beam headlights are on, i used the +ve wire from my driver side lowbeam headlight for the relay signal to activate the relay. Then i ran the on/off switch to the inside where the fuse box is, fit right in the factory hole under the dash.
Thanks for sharing, my mom has a u/s made '05 in black (no fog cutouts) and is begging me for fogs but i keep putting it off for later. might consider.
