Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1984 Corolla engine swapped, now won't run.
View Single Post
Old 08-14-2007, 12:54 PM   #7 (permalink)
ea8631
View ea8631's Photo Gallery
Originally Posted by boss6021
ea8631 which sensor do you mean?
I'm not quite familiar with 2SE, but I will just throw in some question (idea?) to see if it help:
Did you switch the ignition system as well or you still using the old ignition system from the 4AC (Assume yours is a 1984 Corolla, not 1984 Camry)?
The 4AC originally come with two vacuum switch, temperature switch and a oxygen sensor with the emission control computer, did you swap them when you swap your 4AC to 2SE as well?
83 Corolla s/w
01 Prius
ea8631 is offline   Reply With Quote
