Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1984 Corolla engine swapped, now won't run.
View Single Post
Old 08-14-2007, 04:46 PM   #11 (permalink)
EverAE
View EverAE's Photo Gallery
so did you start off with a 4ac? im leaning with what ea8631 did you do all the efi stuff, and what fuel pump are you using, assuming you started off with a 4ac itll have a mechanical low pressure pump above the valve cover, instead of a higher pressure, efi in tank pump?
EverAE is offline   Reply With Quote
