I heard about your PRM filters before too,
They should be really good, obviously they suck air in allot more than all the other air filter because of their shape and the way they're mounted. That's not what I asked you though, on my Corolla, from the actual injector there's a soft rubber pipe coming out, connects to the actual platic tube that goes into the OEM filter box. I took the plastic pipe and the box out and mounted my air filter right on the soft rubber tube, it has support so it's holding the filter up, but the filter bounces because it's rubber.. Now, another problem I have is my air flow sensor that was mounted on the plastic factory pipe, it's just sitting in my engine bay! So, I want to make a custom pipe and cut a place to mount the sensor cause it's affecting my idle since it's getting hot air instead of cold..
pheeeeew! I hope somebody understood this!
So, I guess I should just go and buy a pipe from Crappy tire and do it my self ha?!
Respect
Xenon
_________________
1990 Corolla SR5
<font size=-1>[ This Message was edited by: Xenon on 2002-03-01 16:03 ]</font>
