Originally Posted by jsbenami
Well I now know they are most def different from 90-92. Because Toyota deal said so. The new part came in today at Toyota, this one matching to the last number (a 2 instead of a 1 like the ebay one and the one I bought & returned from Advance) at the end of the number on the black sensor. This one I tossed in and the car runs like a dream again.
Let me amend your earlier statement Jeeves: Its not a bad idea to clean your AFM (when it has 1/2 inch of goop) its a bad idea to spray brake cleaner into the screen like an idiot (that's me!) when you don't know what is inside there  Prob cleaning it with a rag wouldn't do it in like my shot of solvent did it. Lesson learned (the idiot way) remove sensor before cleaning housing.
Also, for future reference, if you have a 90-92 the older AFMs that end with '1' will not work. The car will idle, and choke everytime you touch the gas pedal. I tried 2 AFMs that were probably originally out of 86.5-89 Supras with the same result. One was ebay used, the other 'remanufactured' the second one had no error codes. Lesson learned (the expensive way) again
See, that just doesn't make sense w/all the other logic on the forums. The sensor never changed, I've run both the Lexus, a late model sensor and the early one in my car, all ran fine. I'm more inclined to say that the others were bad.
Here's a SupraForums thread proving it:
http://www.supraforums.com/forum/sho....php?t=226982&
1989 is when Toyota re-numbered their parts catalog.
The only thing Toyota employees know these days is if it has a different part number, so it must be different. This logic is false as many part numbers changed over the years even as they were the same from year to year. The part # on the Lexus AFM that I ran and the Original one in my car were very different, but the sensor itself and how it operated was the same.
As for cleaning it, you said exactly what I did. You should never everrrr put anything near the electronics (the AFM) in the AFM housing. Dismantling it, and cleaning it thoroughly isn't bad (keeping the electronics seperate), hosing the AFM electronics with anything other than air is. I was talking about the electronics as it's actually what measures the air flow.
