New to the Supra scene - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2006, 09:27 PM   #1 (permalink)
View NegritoWhyte's Photo Gallery
My dad owns a '89 Turbo MKIII 5spd, black w/ red metallic flakes and maroone interior. 66k original miles on it. My dad decided to give me the car. This is my first non euro car I've owned. This also is going to be my first FI car I will ever own. Is there any special maintenace I must do?
I really dont know what type of engine I have because the car is in Costa Rica. So when I go down there I would find out or my maybe someone may have an idea.
What could be some minor mod suggestions that I can start with? My dad said that it may new shocks and a clutch. If I change the clutch I might as well change the flywheel with it. So what do you suggestes as well.
I was thinking bov, and exhaust and intake filter. That are good brands that you suggest?
A friend of mine said if I start modding the car I have to get a turbo timer? Is this true??
Thanks in advance.
NegritoWhyte is offline   Reply With Quote
Old 01-08-2006, 12:00 AM   #2 (permalink)
真 Boost Junky. 真
Wolfie's Avatar
View Wolfie's Photo Gallery
First off I removed turbo timer, its wank factor...just leave the car running a couple minutes after a spirited run and that will suffice, having a turbo timer its REALLY easy to steal your car...some dont agree but my supra when i had one i figured out how to keep the car going without a key using the turbo timer.
BOV wise I have a sheep dog BOV from japan, Turbo Smart which is an australian maker but you should be able to get them there make REALLY good quality bov's that release atmo and sound reasonably good and do there job well. Or you could just go for a HKS SSQV, theres many different bov's but some do sound like crap if they are atmo release...with your supra though you will need the plumback kit for the bov, i cant remember what it does but you get problems on 7M's when you dont plumb it back.
Exhaust you can go custom or look into a good 3" catback...i'm running an Apexi Bomber II 3" catback exhaust, i recoommend upgrading the down pipe off the turbo as the stock one is restrictive, get a high flow cat or if legal in the US remove the cat completely out of the picture.
I wouldnt worry about a pod filter or anything, i noticed NO gain at all...intake filter mods are a waist of time and money...if you want one you have to get one that can fit infront of the AFM because unlike a turbo-a you're not running MAP.
Congrats on owning a supra!!!
For the haters that said it'd never happen!!!--->
1990 Toyota Supra, 2JZ-GTE conversion!
Wolfie is offline   Reply With Quote
Old 01-10-2006, 10:23 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Personally I think Wolfie's an Idiot for removing a turbo timer. I don't care if he doesn't like electronics. To remove something as useful as that is like removing gas heating from a house because it's not the way the pioneers did it.
Turbo timers are very helpful, and as you can read on the driver side door panel, there's a sticker placed there to tell you to turbo time the car. The simplicity of them much outweighs their sub-$100 cost. My $0.02, Get one. It was my second mod, and I don't look back on it for a second.
You do not need to plumb the bov back into the intake. Here's the problem. When a blow off valve dumps air to atmosphere, it's dumping air that the computer is expecting to go into the engine. So, it thinks there's more air going into the engine than there is, runs rich for a second, then fixes itself. Coming upto a stop sign, some people have minor stalling issues, others like myself, have NEVER had an issue running a BOV venting to atmosphere.
Personally, I'd recommend the HKS SSQV. It can be piped back into the intake like Stock, or it can go to atmosphere. It also has a better method of functioning than most other BOV's. However, it's not cheap.
In my opinion, the stock BOV is fine, unless it's leaking. As a BOV isn't a performance modification, there's really not a reason to replace it unless it's failing or you're pushing >9-10psi.
The exhaust itself isn't the biggest issue at all, it's the restriction introduced in the stock turbo elbow. My suggestion is to pick up a good 3" downpipe that replaces the turbo elbow, then complete it with a full 3" exhaust system to a free-flowing muffler. Baffled mufflers introduce backpressure (required for NA cars) but bad for turbo cars.
Another reason I think Wolfie's a fool. I noticed an immediate gain when I put on an intake. If you look at where the turbo sucks air from, it's a smalll hole through a dense filter medium that introduces more lag, and limits the turbo severly.
Look into a good K&N Drop in filter, or a K&N Cold Air Induction setup. Both will improve performance a decent amount.
Old 01-10-2006, 01:09 PM   #4 (permalink)
真 Boost Junky. 真
Wolfie's Avatar
you're entitled to your opinion...and i think i'll just leave you people with your little forum (which is more like nissan nation now anyway). I personally think you're arrogant with your opinion, its your right and everyone else is wrong...with that said enjoy.
Old 01-10-2006, 02:02 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
An intake not adding power? You've gotta be foolish to think that. I don't really care what you do, you're spreading mis-information. I hate this forum as much as the next kid because people like you spread information that's not true.
Good Riddance. Don't let the door hitcha where the good lord splitcha.
Old 01-10-2006, 07:03 PM   #6 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
Jeeves is known to be a hardass, but he knows his shit.
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Supra to Cressida Swap Spektyr Cressida Forum 21 01-31-2012 03:21 PM
Annual Canadian Supra Appreciation Days – Toronto 2005 bgrieger Canada 0 02-04-2005 12:54 PM
BAD AZZ supra vids kevganzon Supra Forum 0 09-14-2004 01:27 AM
mk3 supra for sale, sniff, sniff...... cdnsupra Vehicles 5 10-30-2003 01:12 PM
