Quarter Mile Time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2006, 03:29 PM   #1 (permalink)
View lang's Photo Gallery
Quarter Mile Time
What is a stock mkIII supra turbo supposed to run?
lang is offline   Reply With Quote
Old 01-27-2006, 04:26 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Something like 15.2seconds, bone stock.
Old 01-30-2006, 09:53 PM   #3 (permalink)
sbettencourt's Avatar
View sbettencourt's Photo Gallery
no!!! i've seen a stock 88 supra turbo run low 14's on bold tires...
sbettencourt is offline   Reply With Quote
Old 01-31-2006, 12:02 AM   #4 (permalink)
iTrader Score: 25 reviews
View raptorracing's Photo Gallery
by bold do you mean bald; and by that do you mean slicks?? please explain!!
George
84 MKII and 89 MKIII - Money Pits
2008 Yaris RS
raptorracing is offline   Reply With Quote
Old 01-31-2006, 07:22 AM   #5 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
low 14's?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 01-31-2006, 01:48 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
Originally Posted by repinS
low 14's?
+1
It wasn't stock then.
Mk3's completely bone stock aren't fast at all.
Old 01-31-2006, 06:39 PM   #7 (permalink)
View mymk3's Photo Gallery
1/4 mile
A lot of people will say what it SHOULD do, but in reality those things will do high 15, 5 speed and low 15 auto, only if you spend a decent dough things pick up from there.
mymk3 is offline   Reply With Quote
Old 01-31-2006, 08:33 PM   #8 (permalink)
Got Hardass?
Jeeves's Avatar
I'm not sure you've got that right. In factory form there's no reason a 5speed would be slower. It has less loss through the transmission, and the auto's weren't notorious for their fast shifting.
Old 02-01-2006, 02:35 PM   #9 (permalink)
View westsidebigred's Photo Gallery
An 89 supra has 232 hp and 254 ftlbs of torgue and run a 15.1 if you could produce a perfect slip or next to. 88 has a different tranny but all time slips truly stock are 15 and up
my supra and I weighed 3950 and ran a 14.3 @ 95 mph with full 3" exhaust and B.o.v , Air intake
westsidebigred is offline   Reply With Quote
Old 02-01-2006, 04:29 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
/cue buzzer.
The transmission never changed.
All MA70 N/A 5spd's used the W58.
All MA70 Turbo 5spd's used the R154.
The differential's final drive ratio changed...
All 89-92 turbo's had the same ratios (3.73).
All 87-88 turbo's had the same ratios (3.91).
All N/A's had the same ratios (4.30).
As for the weights:
1989+ Turbo - 3650lbs (officially listed)
1986.5 NA - 3450lbs (measured, wet, w/o driver)
1987 Turbo Hardtop - 3440lbs (1/2 tank, minimalist setup, measured)
1988 Turbo (+shit) - 3850 (1/2 tank, all tools, stereo + sub, w/o driver)
1989 Turbo Targa - 3600lbs (1/2 tank, stock, w/o driver, measured)
Stock Mk3 Supra Specs:
N/A Specs:
Horsepower: 200 @ 6200rpm
Torque: 188 ft-lbs
Weight: approx. 3400-3600
Engine: 7M-GE 2954cc
Transmission: W58
Injector Size: approx. 305 - 380cc, low impedance (high impedance 89+ models)
Spark Plugs: NGK BCPR5EP-11
Compression: 9.2:1
Cylinder Pressure: 156
Fuel Pressure: 33-40psi
Coefficient of drag: 0.32 (without wing)
Turbo Specs:
Horsepower: 230 @ 5600rpm (232 89+ models)
Torque: 246ft-lbs (256 89+ models)
Weight: approx. 3500-3700 (Depends on options)
Engine: 7M-GTE 2954cc
Transmission: R154
Boost (M/T): 5.5 - 7.5psi
Boost (A/T): 4.8 - 6.0psi
Turbo: Toyota CT-26
Spark Plugs: NGK BCPR6EP-N8
Injector Size: approx. 440cc, low impedance
Compression: 8.4:1
Cylinder Pressure: 142
Fuel Cutoff: approx. 10-13psi
Intercooler Efficiency: 3psi drop @ 6.8psi
Wheels/Tires: 16x7" Rims with 225/50-16 Tires
Coefficient of drag: 0.33
'Official' 0-60 Times:
Non Turbo:
Motor Trend, May 1986
0-60 mph = 8.11 sec
1/4 mile = 16.17 sec
60-0 = 132 ft
Skidpad = 0.86 g
Turbo model:
Motor Trend, November 1986
(Pre-production model)
0-60 mph = 7.84 sec
1/4 mile = 16.17 sec @ 89 mph
60-0 = 126 ft
Skidpad = 0.86 g
Car and Driver, April 1987
0-60 mph = 6.4 sec
1/4 mile = 15.0 @ 91 mph
70-0 = 188 ft
Skidpad = 0.83 g
Top speed = 145 mph
Motor Trend, April 1987
0-60 mph = 6.88 sec
1/4 mile = 15.40 sec @ 92 mph
60-0 = 126 ft
Skidpad = 0.85 g
Road and Track, February 1989
0-60 mph = 6.6 sec
1/4 mile = 15.2 sec
60-0 = 146 ft
Skidpad = 0.83 g
Car and Driver, April 1989
0-60 mph = 6.2 sec
1/4 mile = 14.7 sec @ 95 mph
Top speed = 146 mph
70-0 = 176 ft
Skidpad = 0.85 g
HP/Weight/Quarter Mile Calculators:
Now, with that info, go to any of these calculators and you'll see that "LOW" 14s are never in the equation. ~15seconds.
http://www.geocities.com/MotorCity/4601/hpcalc.html
http://www.dragsource.com/index.php?...s&calctoview=4
http://www.dragsource.com/index.php?...s&calctoview=5
Quarter mile times? rice Archived Corolla threads 0 01-25-2006 11:48 PM
1/4 Mile time sixersfan_12 1st Generation (1995-1999) 5 03-02-2005 07:13 PM
What time does TN wake up? Slaughter Off Topic 39 07-08-2004 09:51 PM
best 1/4 mile time LOCALCAR Archived Corolla threads 2 03-18-2003 04:02 PM
