89 Turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 04:07 PM   #1 (permalink)
View vykman84's Photo Gallery
USA 89 Turbo
After replacing CPS car seemed to run much smoother (it was leaking oil badly). Then, on occasion, it ran very rough for a few minutes and then instantly ran great. The rough part kept getting worse to the point that now it always runs rough. When I get on it, the motors revs up (and shakes) but there is no power.
I am also loosing coolant. Maybe I have a BHG but there is no water in the oil, the car does not overheat, and the block tester I used from NAPA did not show any exhaust in the coolant. I have a Greddy PCV catch can inline between valve covers and turbo intake and it had a good bit of water and some sludge as well in it. IC line, timing and hoses are fine. The coolant issue is involved somehow but I am lost and could use some advice or it's off to the dealership and they probably will have no clue eithe r.
vykman84 is offline   Reply With Quote
Old 01-29-2006, 04:35 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
If you're getting coolant in your catch can you're obviously mixing coolant and oil. I suspect a bhg.
FS 89 GTS Turbo AWD parts PiercePCassidy Celica Forum 14 01-03-2005 06:24 AM
14b Turbo on My 89 Camry The Yellow Dart 1st & 2nd Generation (1983–1986 & 1987-1991) 11 02-04-2004 12:23 AM
Who have TRD Rally suspensions for a 89 Celica Turbo RERX7 Celica Forum 0 04-21-2002 10:59 AM
