FINISHING BHG job..lost my place - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2006, 04:23 PM   #1 (permalink)
View Walka's Photo Gallery
i have done a lot during this blown headgasket business and i am clipping in the harness on the intake side and forgot where this one goes..i cant find it anywhere
this is what it looks like
anyone know?
Walka is offline   Reply With Quote
Old 01-31-2006, 09:59 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Originally there are two VSV's down there one for EGR one for the Fuel Pressure Regulator. I don't have a running mk3 so I can't go check, but a quick look through my photos I couldn't see that specific connector. My guess is that it's one or the other, EGR or FPR VSV. But I don't know for certain.
The other question, is what year mk3 do you have?
The TSRM seems to show the VSV's, that looks like it could be the right type of connector...
http://www.cygnusx1.net/supra/librar.../ec/EC_14.html
Old 01-31-2006, 10:14 PM   #3 (permalink)
i have an 89 turbo supra
i have both vsv's..i do have that drawing i made to help a lil..i guess its hard to understand
but it shows what is connected and the one that has a question mark there..is the one i cant figure out
Old 02-01-2006, 11:09 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
No clue offhand, sorry.
Old 02-01-2006, 12:30 PM   #5 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
my friends Turbo MKIII had that and it wasnt connected to anything... same goes for my N/A...
Ne0z31 is offline   Reply With Quote
Old 02-08-2006, 04:58 PM   #6 (permalink)
i tried to start it today and the starter tried to turn it and it struggled for a second...then a lil pop from the exhaust but nothing...its not starting
anyone know?
another important question is, how important that lil ground wire on the coil pack is? mine broke off and was gonna replace it
the screw is rounded out..is there more places i can put it?
Old 02-08-2006, 05:21 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
anyone know?
General rule, ALL grounds are important. I'd definatly call that a possibility. I'd also be looking at the Cam Position Sensor. It's also well known for preventing starts.
Does it crank and crank and crank and just never catch?
Old 02-08-2006, 05:24 PM   #8 (permalink)
yea no catch...ill ahve to look at that position sensor..i still need to time it and all...technically i just ahve it pushed in there
Old 02-08-2006, 09:16 PM   #9 (permalink)
Got Hardass?
Jeeves's Avatar
Have you checked for spark and fuel?
Old 02-09-2006, 05:23 PM   #10 (permalink)
testing my timing light on my buddys car i found the light is out..so yea that was use less
but i got it to start and then it just dies..i thought maybe the timing was 180degrees off but nope i checked it the #1 is at its peak when the cams are.
im thinking i didnt gap my ngk platinums sooo i am gonna take them out and check the gap...im pretty sure it has to be .32 so im hoping that is just the problem.
but i got it to start and die...any ideas?...sometimes i hear when the car dies after its off it has a bit of a suction where the intake is, and the airfilter does a slight blow off. there is smoke so i doubt its not getting spark.
the whole time i had my buddys car connected to keep the battery from dieing.
Old 02-10-2006, 12:47 AM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
Check for spark and fuel.
Full a plug wire, slap a spare plug into it, ground the plug out and see if it's firing. That right there will tell you if that ground wire is necessary. If it's firing there, I'd check fuel. But that's afterward.
Old 02-10-2006, 06:17 PM   #12 (permalink)
i was an idiot and installed the cps wrong...actually i just put it on the head..didnt even think that it need to be set at a certain place...lined it with teh drill hole and put it on while at tdc...thx for the help car works now
Celica whole body paint job..know of anyone/any place? nuke da bomb General Discussion 0 08-13-2004 05:53 PM
Job Opp: Investment Rep P/T Phi Off Topic 3 03-31-2004 12:46 AM
Need a place to do minor paint job fallennite Camry & Solara Lounge 0 08-02-2003 10:00 PM
I lost my job, this sucks! Chris Corolla S Off Topic 12 01-08-2003 05:45 PM
ULTIMATE PICKUP LINE LIST!!! camryLI Off Topic 6 07-08-2002 11:11 AM
