Boost...the higher it goes, the faster you do. A simple exhaust and some more boost should suffice for now, then you can go farther when you learn more about the car. Keep it under 10PSI...that little increase wakes it up quite a bit, and doesn't stress the factory stuff too much.
Springs and struts and sway bars are the basic suspension mods...and as far as most people ever go. Koni dampers and eibach springs tend to make their owners very happy, and are IMO a great street arrangement, though on a tight budget, tokico blues can be put in instead of the koni's and seem alright. Alternatively, if your factory parts are still good, some like the tokico's with sway bars and leave the stock springs...doesn't lower the car, but is a very capable and still comfortable street setup. At the high end, there's coilovers. I have a set of Tein FLEX's on my car, and am purchasing whiteline sway bars. I'm overall happy with them, and if I had to do it again, would also consider the Tein SS, lower price, a few less features, but overall a good setup.
For springs and sway bars, you might also look at the whiteline ones that raptorracing is group buying right now. Check the vendor/group buy section in the main forums area for more details. Good price, good seller, supra owner too.
