HP gains i'll leave to someone else...mainly because mental block makes me not remember this early...
As to the fans, you can make up a few ponies switching so long as the electrics are not running. Electrics running, the hp gains disappear, but you still don't get as much air over the rad. Electrics do not push as much air as a stocker can, but require as much energy from the alternator...since energy isn't free, you need the HP to generate electricity...Physics is a bitch.
Many supra owners run electrics with no problem, though many need to switch back as our cooling system is considered fairly marginal. For road course or autox, a clutch fan is a requirement, and in the southwestern US the electrics more often than not can't keep up. A bigger rad may help keep the problems to a minimum.
