Will XX motor fit a XXXX Supra
In a nutshell: Yes. Then again, if you have cash, time and skills, so will any motor. What should be said is that they fit more easily, and can be mounted with almost exclusively available supra parts.
That said, you can then swap the 4M, 5M, 6M, 7M, 1G, 1J and 2J engines fairly easily into any Supra if you have the knowledge of how swaps work in general. In fact, the UZ family of V8 engines swap fairly easily as well.
So, since the answer is stickied, I would expect to see higher level questions about the intricate parts of a swap from now on...
