89 Turbo Supra starter failure when hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2006, 09:59 PM   #1 (permalink)
View kflynn's Photo Gallery
Decent Premium Bosch rebuilt less than 500 starts and back to the same old problem. Won't activate when the engine shuts down (superheat). Good for maybe two stops around town, then on the third no engagement. I am assuming engine heat expands the solenoid piston and it sticks or the bushing fail due to the heat. Let her sit and cool, she starts right up. Any recommendations?
KFLYNN
kflynn is offline   Reply With Quote
Old 03-01-2006, 10:57 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
The term you're looking for is heatsoak, I believe. Not Superheat.
http://www.supraforums.com/forum/sho...t+soak+starter
Old 03-02-2006, 12:01 AM   #3 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
Good ole heat soak. You can put some header wrap or a heat blanket on the starter to help with it.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 03-02-2006, 07:57 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
One other common point is the wiring. A few owners around here have found replacing the starter lead fixes every heat soak type problem they seem to be having. Those with immobilizers tapped in found it first, likely as corrosion in the copper increased resistance. Most of the wires even looked visually acceptible, but the replacement solved it.
Old 03-05-2006, 09:46 PM   #5 (permalink)
Thanks
I will try the wiring. It makes sense due to the condition of the wiring harness. If that fails, I will try my local rebuilder, or just move onto another starter that I found with a heat shield.
Thanks again.
KFLYNN
Old 03-06-2006, 06:07 PM   #6 (permalink)
Status Auto Design
View Fineprint's Photo Gallery
Yea you can make a hrdwire directly to the battery as a ground type deal and definetly make a heat shroud or wrap on it. Mine did that for a while until i did the above stated and havent had a problem since.
Fineprint is offline   Reply With Quote
87 supra turbo...what to look at before buying? wannamk3 Supra Forum 8 04-03-2005 07:21 PM
1990 toyota supra turbo targa, For sale! ajmk31990 Vehicles 1 03-31-2005 06:51 AM
93-96 SUPRA SINGLE TURBO CONVERSION F/S valiente45 Supra Forum 1 03-19-2002 09:46 PM
