Anything with "whiter light" in a stock sealed beam replacement means they put a coating on the bulb, and so lower the amount of light coming out. They simply take away the yellow spectrum, which makes them appear brighter, without really improving the total light output or the beam pattern. I tried the silverstars and they did just that. GE has the nighthawks which are supposed to have a little more light output than the silverstars, but until you step into the H4 e-code replacements or real HID, that's about all you get. That said, there are 65-100watt replacement sealed beams out there, but they will likely blind everyone around, get you pulled over by a cop for it and require you to completely rewire your lighting as the stock stuff will quickly go up in flames.
Bob
