Surging Throttle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 02:33 PM   #1 (permalink)
Super-ah
theKnifeArtist's Avatar
View theKnifeArtist's Photo Gallery
Surging Throttle
so i had a TPS sensor code. so i bought the same one used on ebay that was supposed to work. when i put it on, the idle would go up and down and wasn't right. when i put the old one back and did a little adjustment it was right. but now...the problem is that is when i go past 1500 RPM...its shoots back down to 800 or around there. i can't go faster than 20MPH on a flat surface. Anyone know what could of happened?
theKnifeArtist is offline   Reply With Quote
Old 03-08-2006, 03:55 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Did you look for stored codes yet?
Old 03-08-2006, 05:54 PM   #3 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
Did you calibrate it properly?
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 03-08-2006, 09:20 PM   #4 (permalink)
Super-ah
after the whole deal i cleared the codes and then started it up and reved it all the way to the 1500 i could and the TPS code came back. i dont think i have it calibrated right...but would that cause it to surge? or does that just adjust my idle?
Old 03-08-2006, 09:27 PM   #5 (permalink)
Super-ah
to clear up...it doesnt surge in idle. i surges if i hit the gas. in neutral and park and drive.
Old 03-09-2006, 02:01 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
You have to calibrate the TPS, it's a VERY VERY precise procedure, don't even think of trying to diagnose things till you calibrate it.
Old 03-09-2006, 03:03 PM   #7 (permalink)
Super-ah
right. well i fixed my problem. i had the tps on backwards. not the thing itself, but the blades of the throttle with the blades of the tps. theres a notch on the 2 blades of the tps which i figured the matches up with the blades of the throttle. it actually goes on the other side of the notch. no more surging. i adjusted the tps a little and the idle and throttle seems to be better than from the beginning. just gotta check that code.
Throttle stop setting? Mystos 89-95 Toyota Pickup/Hilux 1 10-06-2005 12:04 AM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
*HELP* RPM inquiry toyotoyota Camry & Solara Lounge 6 06-22-2005 12:43 PM
Answer to engine rock/bounce on throttle lift brink Hardcore Tech and Competition 5 10-23-2003 10:34 PM
93 camry throttle surging sloop 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-16-2003 01:16 PM
