Stall after Immediate Throttle Release - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 10:51 PM   #1 (permalink)
Super-ah
theKnifeArtist's Avatar
View theKnifeArtist's Photo Gallery
so my car has been stalling. its automatic by the way. i realized it happens when im giving a good amount of gas and i immediately let off(not fast driving maybe 10-15mph max). what could be causing this? i adjusted my TPS and doesn't seem to be that. i found a thread on here about that before but i cant find it again. any ideas?
theKnifeArtist is offline   Reply With Quote
Old 03-17-2006, 07:35 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
A couple of other things: Dashpot. It stops the sudden slam of the throttle plate, and lets the engine stabilize. If it isn't working or is out of adjustment, you may stall.
Idle stabilizer valve: if this is getting stuck, you may have a problem.
Boost leak/BOV: externally vented BOV, or a cracked pipe would do it. You should though not be able to build much boost either.
Gasket: I had a similar thing that was accompanied with really rough running. Turns out the EGR gasket was shot. That small a leak was enough.
That list should take the weekend to test through. Let us know how it goes!
Old 03-17-2006, 10:36 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
I removed my dashpot setup, saw no difference.
I'm guessing the Stock BOV has failed and is leaking. Pull it off, and blow through it. If you can blow through it both ways, it's failed.
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
2006 Scion xB Release Series 3.0 (official) dlundgren Scion Forum 0 01-06-2006 01:14 PM
Throttle stop setting? Mystos 89-95 Toyota Pickup/Hilux 1 10-06-2005 12:04 AM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
Answer to engine rock/bounce on throttle lift brink Hardcore Tech and Competition 5 10-23-2003 10:34 PM
