I've been trying to get this car running properly and haven't had much luck. I want to know how to run diagnostics on it with the check connectors. There are two near the front passenger side fender in the engine compartment that I don't know what they're for or how to make use of them. In my wiring diagram book they're labeled the oxygen check connector (has one terminal) and emission check connector (has three terminals, VF,
VB, E1 according to my book). My Chilton's manual talks about shorting T to E1 and using the check engine light, but there isn't a T terminal nor a check engine light? Also, it idles high at over 1200 rpms and the manual says I need a special service tool, do I really? It looks like it's just a plug for the emission check connector that can connect easily to a voltmeter so can I use something else?
