common fuel stand alone systems questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2006, 08:02 PM   #1 (permalink)
View driftmagic1's Photo Gallery
ok ive got a 7ngte in and ae86 i know its not a supra but it is a supra anyways i was wondering what stand alone fuel systems you guy use the most
driftmagic1 is offline   Reply With Quote
Old 03-26-2006, 09:29 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
autronic, haltec, motec, sds, megasquirt on some...all the common ones.
Old 03-27-2006, 09:55 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Have you actually seen a Megasquirt up and running on a 7M-GTE? I've seen 'em on N/A's but never on a working GTE. I'd be curious to see it, last I heard it was having issues with the ignition and CPS in the GTE.
Old 03-27-2006, 01:04 PM   #4 (permalink)
bgrieger's Avatar
The solution I have heard of is to grind teeth off the CPS to give it the same output signature that everyone else uses on the crank triggers. I haven't seen one running, only heard of one or 2 reports now. The NA's have no problem though.
Old 03-27-2006, 02:13 PM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
That's pretty much what I'd heard too..
Old 03-27-2006, 05:14 PM   #6 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
You can use the MS2 on a turbo 7m using a ford EDIS-6 ignition module, VR sensor and trigger wheel, the next release of MSII should have wheel decoding to use the stock CPS.
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 03-27-2006, 06:00 PM   #7 (permalink)
hey thanks fellas i was talking to my freind today and there is a guy close to here that has the haltec system so ill check it out and go from there thanks alot
1ZZ, 2ZZ, and 1NZ fuel systems slipknot490 1st Generation (2003-2008) 6 10-22-2005 08:38 PM
5SFE Fuel Upgrades luisitol 3rd & 4th Generation (1992–1996 & 1997–2001) 65 05-31-2005 07:25 PM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
Guide To Nitrous Sportivo Concepts Hardcore Tech and Competition 2 10-09-2003 03:25 PM
Interior Trunk and Fuel door latch questions Papa Georgio Archived Corolla threads 2 05-27-2002 06:40 PM
