Need Help:88 Injector wiring diagram - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2006, 04:59 PM   #1 (permalink)
Toyota Daddy
chinesemechanic's Avatar
View chinesemechanic's Photo Gallery
3rd Generation Need Help:88 Injector wiring diagram
I have a 1990 supra that had a blown motor. So i put one in from an 88 but my mechanic just spliced into the injectors instead of switching the fuel rail. Now it cranks fine and compression, timing, fuel, and air check out but there is something fuckered up in the injectors i think. If you splice into injectors wires shouldn't you soder them and then seal them up with that shrink wrap or use a butt-connector. Any help would be greatly appreciated. I'm tired of not being able to drive it.
chinesemechanic is offline   Reply With Quote
Old 03-28-2006, 06:07 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
That's how I've done injectors, how'd he do it?
Really, you just said fuel checked out, How did you test it?
Old 03-28-2006, 06:28 PM   #3 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
Time for a new mechanic, yikes.
Solder and shrink wrap each wire. Make sure the wires are going to the correct ones. Ex. #6 injector has #6 injector clip from the harness plugged into it.
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 03-28-2006, 09:36 PM   #4 (permalink)
Toyota Daddy
Well when i crank on it for a while it will start but for like a whole second and then die. I hooked a noid light up to it and a couple injectors arent getting spark but i wanna to double check his "splicing job" because the 90 wiring harness has different colors than the 88. I wanna check before i go and soder and shrink wrap them shut. Its got fuel pressure too. I heard that they switched from low imp. to high imp. injectors around 89 so since im using the 90 wiring harness and comp. would i need to switch the injectors too?
Old 03-28-2006, 10:55 PM   #5 (permalink)
SuprAdam's Avatar
Injectors should be the same for all 7m mk3's, of course varying if you are turbo (440cc) or non-turbo (3XXcc).
I really don't understand why he couldn't undo the clips and just unplug them instead of cutting them. It would have taken him less time to do that instead of bothering with splicing/soldering..... The clips are no different than the 30 others that had to be disconnected to pull the engine. I can not stand the dumb shit shops do...
- 1986.5 Supra
Old 03-29-2006, 12:29 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
SuprAdam,
That's incorrect, the impedence changed on the N/A Injectors from the pre-89 to the 89+ years. Turbo's however, used the same impedence across all the years.
Pre-1989 Change:
7M-GE - Low Impedance [Color: Yellow, 2.7ohm, 295cc, Type: Dual Ball Valve, Engine: 7M-GE (US -89.8)]
7M-GTE - Low Impedance[Color: Black, 2.9ohm, 430cc, Type: Dual Ball Valve, Engines: 7M-GTE, 3S-GTE (-89.8]
1989+
7M-GE - High Impedance [Color: Light-Green, 13.8ohm, 315cc, Type: Dual Ball Valve, Engine:7M-GE (US 89.8+)]
7M-GTE - Low Impedance[Color: Black, 2.9ohm, 430cc, Type: Dual Ball Valve, Engines: 7M-GTE, 3S-GTE (89.8+)]
Mk4 TT's ran 550cc's from the factory. The biggest issue in using them in a mk3? The impedance. Their impedance is like 13.8Ohm. In fact, I think once OBDII hit, all Injectors ran @ 13.8Ohm.
For clarification, Cylinders get spark and fuel, Injectors supply fuel, spark plugs supply spark. If some aren't getting fuel, while others are, I'd say match the wiring from one of the injector's that's working to one that isn't. I'm still curious, what method did he use to wire 'em together?
Really, what this actually sounds like is a damaged cam position sensor wire(s).
On the passenger side of the block, near the front, there is a round thing sticking out of the head. Out of it are four wires, they plug into a harness. Jiggle the wires, and the harness while someone cranks. My bet is that's where the issue is, not spark or fuel.
Old 03-29-2006, 01:18 AM   #7 (permalink)
SuprAdam's Avatar
Originally Posted by Jeeves
SuprAdam,
Pre-1989 Change:
1989+
bah nobody cares about the damn n/a's!
Mk4 injectors won't work on a mk3 without a custom fuel rail setup...MK3 uses top feed injectors, mk4 uses side feed.
And yes the problem could be a number of things...Clean up your wirring firstly then clear your engine codes, turn the engine on and then check for codes. If you have spark, and fuel, chances are your issue is timing (cps like jeeves said.) Timing could be way off or you could just be a tooth off on the CPS gear.
- 1986.5 Supra
Old 03-29-2006, 10:07 AM   #8 (permalink)
Got Hardass?
Jeeves's Avatar
I'm not saying it's timing at all, I'm saying the wires are well known to be baked by heat, become brittle and fail to work. It's incredibly common on the 7M-GTE due to the CPS' proximity to the turbo, exhaust manifold and the head in general.
If the ECU fails to see an Ne or a G signal while it is cranking it will not produce an IGt signal, thus preventing igniter operation.
It's the green connector.
Old 03-29-2006, 02:38 PM   #9 (permalink)
Toyota Daddy
So since im using the 90 ecu and the motor has the 88 injectors, do u suggest i get the high impedence ones. Cause 2.7 ohms and 13.8 ohms is a big difference and couldnt that mess with the ecu signal a bit.
By the way he just cut the wires about 3 inches from the injectors so that he didn't have to mess with the throttle body and the intake manifold. And then he jsut wire crimped them together. What a lazy ass corn-cob.
Old 03-29-2006, 04:13 PM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
Are you N/A or Turbo? Turbo it doesn't matter (they're the same), N/A it's a big deal. Nevermind, I just read your profile. Yes, those injectors are different. Swap in the old ones and try again.
Are you sure they're not shorting?
Old 03-30-2006, 07:35 PM   #11 (permalink)
Toyota Daddy
You may have that type of sensor on your turbo but i think mine just plugs into my distributor. You turbo guys have your fancy coil packs. Do u guys know of anywhere where i can get some injectors for a reasonable price. Autozone and Advance have some but they are pretty expensive.
Old 03-30-2006, 09:52 PM   #12 (permalink)
SuprAdam's Avatar
used on ebay or on Supraforums.com / supramania.com for sale sections.
You can probably easily get n/a injectors (all 6) for $50 or less.
- 1986.5 Supra
wiring diagram for 1999 camry tinman831 Audio, Video, and Security - Tech 2 12-03-2011 11:13 AM
RAV4 ECU Pinout diagram for E-manage almc2242 Hardcore Tech and Competition 5 07-27-2008 02:11 AM
wiring diagram damo Camry & Solara Lounge 3 08-07-2004 11:07 PM
