85' Supra Headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2006, 08:11 PM   #1 (permalink)
PRAIRIEDOG
View prairiedog's Photo Gallery
I have an 85' Supra with the popup headlights, and I was wondering if there is a conversion kit anybody makes so that they arent popup's anymore.....
HELP
P*L
prairiedog is offline   Reply With Quote
Old 03-29-2006, 12:32 AM   #2 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
you have to make it custom
Ne0z31 is offline   Reply With Quote
Old 03-29-2006, 12:52 AM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
And I've yet to see one that looked good for that car. Popups > Built in.
Old 03-29-2006, 07:59 PM   #4 (permalink)
PRAIRIEDOG
OK I've saw them on other cars such as rx-7s and they looked pretty tight....
thanks
P*L
Old 03-29-2006, 11:52 PM   #5 (permalink)
Always on the Warpath--->
xrs22's Avatar
View xrs22's Photo Gallery
I had thougt of just buying another headlight cover from a wrecking yard for the passenger side and make a vent of it for the intake. I guess that was off subject but it had headlight in it so i guess it was ok.
xrs22 is offline   Reply With Quote
Old 03-30-2006, 09:24 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
thanks
Up to you. I've just seen too many attempts that ruined the lines of the car.
Old 03-30-2006, 04:07 PM   #7 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
popups always gave me that sports car feeling...
Old 04-05-2006, 10:35 PM   #8 (permalink)
midwestmk2's Avatar
View midwestmk2's Photo Gallery
If you mod the fog lights then who needs headlights..I dont.. Here is how its done..
1.remove the stock fogs from car.
2.stick the entire housing into a oven stitting at 300deg for about 10 min..
3.Take the housings out and carfully pry out the stock lens with a screwdriver while still hot(loosens glue).
4.After removal of the lens remove the reflector in the middle of the inside of the housing,Its only held on with 2 rivets.
5.reinstall the lens and seal it with hightemp silicone then get some 100watt bulbs..
Now you should have significantly brighter lights..If that is not bright enough for you then instead of putting in the stock lens's buy some 1/2" thick glass and have them cut to fit your housing(any window shop can cut them for you).. I did and also took out the headlights altogether and hard wired my fogs to the low beam harness just to make sure they wouldnt fry the stock fogs harness.. Here is some pics of mine..
This is my conversion..
Here is a closeup..
These are a side shot and a front of the brightness of 100watt halogen bulbs with the conversion..
This is the pattern that is given off by them..My Mom lives out in the boonies and these work just fine on dark backroad 2 lane highways..I only had a problem in a HARD rain but it was becaes of rain not the lights..Wipers wouldnt go fast enough..
Let me know if you got anymore questions..
http://www.cardomain.com/ride/858848YEAHRIGHT!!Like that CIVIC ever stood a chance!! MY SUPRA MADE ME DO IT!!! For real officer I SWEAR!!
midwestmk2 is offline   Reply With Quote
Old 04-05-2006, 11:00 PM   #9 (permalink)
PRAIRIEDOG
hey midwest, do you have high/low beams now or just one in between
P*L
Old 04-06-2006, 03:48 AM   #10 (permalink)
midwestmk2's Avatar
Just one inbetween.. Like i said i hard wired mine into the headlight harness so im only using the low beam circuit..If flip the high beams on the fogs go out and your all dark..
Every now and then i have someone flash there lights at me..I just made sure i had them adjusted just right..I spent almost a hour on just that..
Old 04-06-2006, 08:03 PM   #11 (permalink)
PRAIRIEDOG
ok cool thanx
P*L
85' Supra prairiedog Supra Forum 2 03-07-2006 09:45 PM
BAD AZZ supra vids kevganzon Supra Forum 0 09-14-2004 01:27 AM
'85 Celica Supra Supra Trupra Supra Forum 7 07-12-2002 06:09 PM
'85 Celica Supra Supra Trupra Celica Forum 6 06-28-2002 11:38 PM
