Drives like a tank. (P/S) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 12:52 PM   #1 (permalink)
View toymk3's Photo Gallery
A question for Jeeves or Bgrieger or anyone that knows. I bought another 89+ Supra that has no powersteering. I replaced the power steering pump, flushed the lines and cleaned the screen of the reservoir, bled the air out as per the TSRM. I understand the concept of the PPS system somewhat. If the connector to the PPS selinoid is unplugged do you loose all powersteering? Ever take a rack apart? Tnx.
toymk3 is offline   Reply With Quote
Old 03-29-2006, 01:40 PM   #2 (permalink)
View celica supra 83's Photo Gallery
If you have a good pressure out of your return line that means your pump works just fine(unplug the return line,start her up and see if there is any flow)
you can check your pps resistance which should be from 6 ohm to 11 ohm(between sol+ and sol-).You can apply 12 V directly to the solenoid connector to see if it clicks(not more than 30 sec or might damage)If faulty replace pressure control valve with solenoid.Anyway,thats all i can think of for now.Might be your rack that is shot too.
have fun.
celica supra 83 is offline   Reply With Quote
Old 03-29-2006, 02:17 PM   #3 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
1) I assume after you did all that, the PS still doesn't work?
2) I've never had to disassemble the rack.
Old 03-29-2006, 07:21 PM   #4 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
You did put a belt on right? (just checking)
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 03-29-2006, 08:54 PM   #5 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
Unplugged, the PPS operates at full assist at all times IIRC. Raptorracing has the same thing on his 89, which is also unplugged. Basically, the car will feel like an 87-88 does, which is a little overassisted at all times, but really not all that bad.
Now, if you still have no assist, you may have problems with the rack itself, and that's never a good thing. Yes Toyota used to sell a rebuild kit (don't know if they still do or not), but I'd personally rather just get a rebuilt from NAPA...quicker and far simpler. The TSRM and I think the Haynes manuals have the procedures for rebuilding, but again, something I'd not bother with myself...
Old 03-30-2006, 09:15 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
That's why I didn't know what the plug was, it's for the variable assist in the later years (something I don't have on my 88).
Old 03-30-2006, 12:22 PM   #7 (permalink)
Thanks guys! I should be able to figure it out this weekend hopefully. I spent the last few days with the milling machine and lathe making a test device that will mate up to the banjo fittings at the pump side. Will be able to measure the pressure and head pressure of the pump.It really does look like the rack, the control valve part of it. I know the fluid is circulating but there must be a problem with that valve. The pps solenoid is also a small part of it, but what I've learned is even with it disconnected, there will still be power assistance. Hence, the rack. Given the parts, (the teflon washers and seals), I would like to try and rebuild one, but a remanafactured one is the way to go for now. $330 at Champion, 400 at Napa in town. I think I'm going to forfeit the core charge and keep the old one to figure this problem out. Thanks again, and I'll share the knowledge when I figure it out.
I have gas leaking from Charcoal canister, nothing in the search for this. Troyfrezze Camry & Solara Lounge 11 01-12-2007 12:58 PM
First time hitting over 300 miles with tank halfway full. xpeed Camry & Solara Lounge 19 02-28-2005 05:09 PM
Gas/Fuel tank Leaking?? Troyfrezze Camry & Solara Lounge 3 02-15-2005 08:27 PM
Gas tank leak? Troyfrezze Camry & Solara Lounge 0 01-21-2005 06:01 PM
replacing gas tank in a '92 sally Archived Corolla threads 5 11-20-2004 04:29 PM
