Head gaskets do not "hold" boost.
A head gasket's purpose is to seal the head to the block.
Good Seal = Ability to maintain compression in the chamber
HOWEVER,
Detonation (Also known as Kocking/Pinging (NOT Rod Knocking)) also occurs more frequently at elevated boost levels and it kills head gaskets. So, Metal head gaskets (MHG's) resist the effects of
detonation much better than composite (OEM) head gaskets do.
Really it all comes down to tuning. In theory you could run 200PSI on a composite gasket, if it wasn't detonating, would one sanely try it? No, MHG's afford you that little bit of buffer space between destroying a head gasket and tuning.
Lastly, What is a "Rock Head Gasket"? Never Ever heard of 'em. Even a google search showed two whole items.
