2jzgte vs 2jzge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2006, 10:18 PM   #1 (permalink)
View rice's Photo Gallery
2jzgte vs 2jzge
besides the turbo difference, what else is different on these models? i know the turbo responds well to mods, but what about the non turbo, and you go aftermarket turbo on it, will it respond the same as the stock 2jzgte that came from the factory? in other words...an aftermarket turbo on a 2jzge responds as well as the stock 2jzgte??
are the engines made the same? other than its turboed? same pistons, compression ratio? etc etc? stuff like that? thanks
rice is offline   Reply With Quote
Old 04-18-2006, 11:59 PM   #2 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
They have different compression ratios. The 2JZGE is about 9.6:1 as compared to the 2JZGTE at 8.5:1. The 2JZGE can run a turbo, but you won't be able to run as much boost because of the higher CR pistons. Your effictive CR will climb faster. With about 9psi boost an 8.5:1 engine will have an effective CR of about 13.7:1 and a 9.6:1 motor will have an effective CR of about 15.5:1. In terms of how the engine will respond the higher compression NA motor will not like more boost. The NA motor will however make better low end TQ. Which in the real world of daily drivers is preferable to a laggy boosted to hell dyno queen.
My general recomendation on which motor to go with is this:
If you are doing a mild build then go with the 2JZGTE. It will cost less than rebuilding the 2JZGE for boost.
If you are doing a major build in which you have to replace the internals to handle more power then finding a rebuildable 2JZ core is the way to go. If you can't find one then get a 2JZGE, strip it, and build it up.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
usdm 2jzgte engines Five1Oh Supra Forum 20 09-25-2010 02:26 AM
1993 gs300 2jzgte swap jdmaddiction General Lexus Discussion 0 10-27-2005 08:58 PM
Bosch Platinum 2 Plugs with 2JZGE engine furballi General Discussion 6 09-03-2005 07:52 AM
ijzgte and 2jzgte clips forsale ninesales Supra Forum 0 08-03-2004 06:49 PM
