I got $4000 to spend, I need a fast car! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2003, 11:31 AM   #1 (permalink)
View SupaMuna's Photo Gallery
New member, and Toyota Tuner, anyway ive got an 90' Supra Turbo (only $1k ) I got $4,000 to spend on upgrades but dont know what to get, Any suggestions?
SupraManBoyDude
SupaMuna is offline   Reply With Quote
Old 02-11-2003, 11:25 AM   #2 (permalink)
Come On
...Please this is my first car I just started reading the manual for it and am confuse on what to buy first.[/b]
SupraManBoyDude
Old 02-11-2003, 01:45 PM   #3 (permalink)
View cdnsupra's Photo Gallery
The mods you buy depend on where you wanna end up. the basic upgrades everyone gets first are Air Filter, Downpipe, Cat-Back exhaust, and Boost Control.
if all you want is to rais the power from 200rwho to 250rwhp, you can go with any kind of setup using these four basic upgrades. The cheapest way to get to this power is a K&N factory drop-in($$30), home-made downpipe with 2 45deg elbows and some welding($$50), cat-back exhaust in 2-1/2" custom bent($$400), and a couple washers for boost control($$1).
if you wanna get to 300rwhp, you need to buy the better choices of those 4 basic upgrades, plus do a few other things. So now, you need to get a K&N filter charger kit($$200), HKS or similiar 2-1/2" - 3" downpipe, 3" hi flow cat-back exhaust($$600), 3" hi-flow cat($$200), and Electronic boost controller like the profec "A"($$700). You will also need to adjust the timing, use light weight oil, new plugs/wires, unorthodox pulley,. etc....
You can run both of these setups at 12psi on the stock turbo, and your reliability will not suffer a bit unless you are a crazy abusive driver.
If you wanna run even more hosepower, you have to start with the better components, then start adding other things like turbo upgrade or replacement, intercooler, bigger injectors, better fuel map system, stand alone fuel system...these items can easily cost $$1000 dollars or more each!
As you add more mods, the increase bang for your buck drops the most cost efficient hosepower can be found back at the basic upgrade level buying the cheaper components.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 02-12-2003, 11:46 PM   #4 (permalink)
View Tosh's Photo Gallery
don't forget bout the internals. If you want to go big, like really BIG beef up the engine. there's a good write up on supramania.
but first up, get a metal headgasket in there.
boost is an addiction
Tosh is offline   Reply With Quote
Old 02-14-2003, 11:17 AM   #5 (permalink)
thanks
Thanks alot for your help.
Old 02-21-2003, 12:21 AM   #6 (permalink)
View Tiger_06489's Photo Gallery
Most guys that I've hung around with have gone with the metal head gasket & arp headbolts. Then a dp and exhaust is next in line. That allows the turbo to spool up reaaaaaaaal fast. Those are the first few upgrades. Next is the intake, electronic boost controller and boost gauge. Ummmmmm, i can't think of the other stuff off the top of my head, so good luck and pm me if ya need help. peace
Tiger_06489 is offline   Reply With Quote
