2jz with a R-154? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2006, 10:28 AM   #1 (permalink)
Toyota Daddy
chinesemechanic's Avatar
View chinesemechanic's Photo Gallery
3rd Generation 2jz with a R-154?
Will a 2jz bolt up to a R-154 tranny or do i have to get the tranny out of an MKIV.
chinesemechanic is offline   Reply With Quote
Old 04-20-2006, 11:42 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
They will not bolt up. You will need a MkIV Tranny of some sort. And a used Getrag V160 goes for something like $2500.
Old 04-20-2006, 12:21 PM   #3 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
I believe it might be possible if you use a 1JZ R154 bellhousing. The bolt patterns should be the same.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 04-20-2006, 12:23 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
I'd heard that, but never heard it confirmed.
Guess the fun then would be tracking down a 1jz R154 bellhousing.
Old 04-20-2006, 12:27 PM   #5 (permalink)
TcmaBoy's Avatar
They pop up on e-bay all the time.
You can also order JDM Toyota factory parts here;
http://www.trademotion.com/memberser...&siteid=213747
You would also need the 1JZ fly wheel, a MK III turbo(7MGTE) clutch, throw out fork, slave cyl, and starter.
Old 05-01-2006, 12:56 PM   #6 (permalink)
View soarer1023's Photo Gallery
i believe that set up can be done, i know there is a MKIII supra with JDM 2JZ, bolt on a R154 tranny, and that beast is pushing out about 500hp
soarer1023 is offline   Reply With Quote
Old 05-01-2006, 02:32 PM   #7 (permalink)
Got Hardass?
Jeeves's Avatar
Well, I know you can't just bolt 'em right up. That doesn't quite work.
Old 05-01-2006, 02:38 PM   #8 (permalink)
TcmaBoy's Avatar
With the parts I listed it will bolt right up. No custom fab work needed. I'm running an R-154 with my 1JZ. I know the crank bolt patterns are the same, so the 1JZ flywheel will bolt to the 2JZ. The only questionable part is the bellhousing. Most of the bolt patterns between the 1JZ and 2JZ blocks are the same, so the bellhousing should bolt up as well.
Old 05-01-2006, 04:01 PM   #9 (permalink)
Got Hardass?
Jeeves's Avatar
I was specifically meaning that an OEM R154 is not going to just bolt up to the 2JZ. I personally know jack shit about the 1JZ and it's associated parts.
Old 05-01-2006, 09:33 PM   #10 (permalink)
TcmaBoy's Avatar
All my parts are OE Toyota. I bought a reman R-154 for a 7MGTE and ordered the corect bell housing from a JDM parts supplier. The bell housing and transmission are two different parts, however they are usually sold as a unit.
Old 05-02-2006, 10:19 AM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
You're combining parts. Sure you may make it adapt, I was saying you cannot remove an R154 from a 7M-GTE, and go slap it on a 2JZ.
Old 05-03-2006, 02:32 AM   #12 (permalink)
i know what u talking about now, with what u saying of course not, but with R154 bellhousing, everything will go right up.
Old 05-03-2006, 10:49 PM   #13 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
Yes it can be done.
A friend of mine has one on his 2jz mk3.
Jz bellhousing and just a regular r-154.
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 05-04-2006, 12:46 AM   #14 (permalink)
TcmaBoy's Avatar
Originally Posted by SuprAdam
Yes it can be done.
Ah, so the 1JZ housing does fit.
Old 05-15-2006, 12:20 AM   #15 (permalink)
Got Fatass?
View ahmedootie's Photo Gallery
i have a jz bellhousing...PM me if interested!
1987 black Turbo Targa 5 spd (RIP 8/29/03)
1987 red Turbo Targa 5 spd (SOLD 6/23/04)
1987 brown Turbo Targa 5 spd (SOLD 12/19/05)
1987 maroon Turbo Targa 5 spd (SOLD 2/17/06)
1991 Black Turbo Targa 5 spd (Under Construction)
ahmedootie is offline   Reply With Quote
1jz on 2jz sbettencourt Supra Forum 1 01-31-2006 02:04 AM
2jz Trany Question.... LandMax Supra Forum 4 11-20-2005 09:25 PM
2jz -> sr20 Injector ? Piddy Hardcore Tech and Competition 1 04-22-2005 12:04 PM
2jz manifold on 1jz? ijzsc300 Supra Forum 2 03-30-2004 10:36 PM
