Originally Posted by Jeeves
I know nothing about them. Are they actually hydraulic? The ones in the Mk3 Supras are electronic.
Electronic lifters? The 7M doesn't have lash adjusters. Nor does it have rocker arms to be adjusted. It uses a direct actuation valve train with solid shims to keep valve lash correct.
I found the procedure in my Haynes manual. It says:
Immerse them, one at a time, in a container of light oil. Insert a pin punch into the plunger hole to depress the check valve and slide the the plunger up-and-down several times while pushing down lightly on the check ball.
Basically use a punch to open up the little valve and work the adjuster to get it to suck in the oil.
