(Jeeves) Going off of synthetic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2006, 01:40 PM   #1 (permalink)
View jsbenami's Photo Gallery
I read a thread by Jeeves saying how he was on full synthetic. I am on mobile 1 0-40 full synthetic. Top of the motor is starting to run a small bit. If I switch back to regular oil, to slow the leaks (all my top gaskets will be redone anyways when I do my valve lash adjustment next fall) is there any forseen badness that could happen....should I go to a blend instead of just Castrol GTX or similar dino oil? Thanks.
jsbenami is offline   Reply With Quote
Old 04-27-2006, 03:21 PM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Not really. I swapped back and forth a few times. Make sure the oil change is good, and if it's really important to you. Change it to some cheap, crappy 10w30, drive for 10-15mins. Then do another full change to the oil of your choice.
Depending on the oil, I'd just say replace your valve cover gaskets ahead of time. they're easy to get off.
Edit: I just noticed what you typed: "Mobil 1 0-40", I'm hoping you meant "Mobil 10w40" and not "Mobil One 0W40". Our cars should not run 0W oils. 0W's are common in things like new BMW's and such. We do not have an engine like they do.
Old 04-27-2006, 08:41 PM   #3 (permalink)
Yes....0W-40, that was not a typo. I though that was thicker than 10W30 Mobil-1? I guess you'll have to educate me then Well in any case its back to good old 10W-30 Dino oil, Castrol GTX anyways.
Old 04-28-2006, 10:32 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
Other way around. The larger the number, the thicker it is.
Engines need oil that is thin enough for cold starts, and thick enough when the engine is hot. Since oil gets thinner when heated, and thicker when cooled, most of us use what are called multi-grade, or multi-viscosity oils.
The common oils we use are called "Multi-Grade" or "Multi-viscosity) oils. A standard oil has A single viscosity, i.e. "SAE 40 OIL".
"Multi viscosity oils work like this: Polymers are added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot."
Take for instance an 10W-40 generic oil. Now let's break down what this really means. What it does mean is that at cold temperatures it will flow like a 10W yet flow like a 40W oil at higher temperatures. Keep in mind that Low is 0ºF (-17ºC), and High is 210ºF (98ºC).
For more good reading: http://www.repairfaq.org/filipg/AUTO/F_oil_facts.html
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
Changed all oil to Mobil1 Synthetic d1live 2nd Generation (2005+) 22 04-15-2007 11:24 AM
first oil change 05tacoma 2nd Generation (2005+) 76 03-03-2006 11:08 AM
changing to synthetic oil? rice Archived Corolla threads 17 08-03-2005 09:33 PM
Chaning to Synthetic Oil on 2002 Camry XLE V6; Question... Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 8 09-11-2002 06:53 PM
