CT20 to CT26 Turbo Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2006, 10:14 AM   #1 (permalink)
edgextreme's Avatar
View edgextreme's Photo Gallery
My 86 pickup is currently burning through oil like it's a 2 stroke so from what I'm being told it's looling like the turbo's to be blaimed for this. I could find out for sure by removing the turbo but since it's my daily driver I'd rather not mess with it until I get replacement parts, I'm not experiencing any noticable preformance loss and it's been this way for awhile so it will hopefully hold until I can replace it. The factory turbo is a CT20 which is considered by most to be a glorified paperweight due to reliablity issues, the life expectancy is 60,000 miles so I should be lucky it's gotten this far packing 115,000 miles. I'm looking at purchasing a CT26 turbo and with light modification fitting it to my 22RTE. The CT26 turbo that I'm looking for came in a MA70 Toyota Supra with a 7M-GTE, it's not to be confuse with the dual entry version that was found on the MR2 and Celica. There is a fair amount of information out there for this swap but I don't anticipate it to be a walk in the park due to my inexperience dealing with turbos. If anyone knows of a link or has first hand experience of this conversion I'd appreciate any help I could get. I could also use a line on purchasing a CT26 turbo as the only turbos I can find are missing the internal/intergral wastegate actuator which is a necessary component for the swap.
Thank you,
EdgeX
edgextreme is offline   Reply With Quote
Old 05-19-2006, 11:37 AM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309050
View bgrieger's Photo Gallery
CT-26 may be a big turbo upgrade for your truck. It should be a fairly easy swap if you can get an adpater made for the bolts to the manifold (if required), and of course you will need a down pipe grafting the 26's outlet to the rest of the exhaust you already have.
The water and oil lines you would take from the 26 and find a way to match the truck's lines up with hoses, and the oil retrun you may need to hacked each in 2 and splice the 26's turbo side to the 20's side where it attaches to the block.
I rarely see 26's without the actuators...try the for sale section of supramania.com, or if you have an account, supraforums.
Thanks,
Bob
Old 05-19-2006, 12:14 PM   #3 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
Just sell it and get a Taco. The CT26 swap has been done. I haven't really looked into the specifics of it. I do know that your boost threshold, the point at which you start to make boost, is shifted much higher in the RPM band. I would contact LC Engineering. They are the 22R gurus. Other places to look for info would be TTORA, Pirate 4X4 and Yotatech.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
CT26 Turbo fits on 4A-FE? 91_CorollaWagon Archived Corolla threads 6 04-11-2006 12:31 AM
SW20 Turbo Swap... robertsmb MR2 Forum 5 12-15-2005 07:37 AM
CT26 Turbo swap marty Hardcore Tech and Competition 2 02-10-2004 10:28 AM
