You have a suite of issues.
I assume you mean the stock boost gauge isn't working. Forget about it, it's worthless anyway, save yourself some headaches and buy an aftermarket one.
Speedo being off, could be the speedo cable, could be the adjustment setting behind the gauge. Replace the cable first, if it persists, look at adjusting the speedo.
Brake lights aren't a common issue. I'd check to make sure the brake switch is functioning (it's attached to a metal bar above the brake pedal, look under the dash area there for it).
Driveline, it could be the U Joint, could be several other things, can you isolate what part is making the noise?
That sounds like a Cam Position Sensor problem, search for "CPS" or Cam position sensor here, I've talked about it a lot.
CAI's, just use eBay, or make your own.
