Different: transmission, drive shaft, differential gearing, intake manifolds, cams are different, ECU, air metering system, block lacks oil squirters on the GE, oil filter mount...the list goes on...
Same: bore and stroke, head ports
Of course, there are a couple of revisions to the engines, and even a GTE isn't the same as every other GTE, and conversely the GE differed slightly from year to year. Most notably, the cranks changed from a semi counterbalanced to a fully balanced design in mid year 89. You need to know the car it came from, or pull the oil pan to find out.
