It's easy to misalign the orings and not seat the injectors correctly. Fuel injector cleaner is not the problem, unless you ran it near straight!
Take it all off again, pull the injectors out, replace the orings and the injector grommets with new ones so you can be assured and try reassembly again.
BTW, there is a pair of contacts in the diagnostic terminal you can jumper to run the pump full time without the engine so you can check for leaks before you go to the trouble of reassembling the intake...
