Originally Posted by toyomoho
Great idea, try swapping valves out. My thinking was, how much brake pressure is required to bleed the brakes with the speed bleeder valve open. I don't know. I would assume if there was enough pressure inside the brake system to overcome the check valve in the bleeder, this might cause the brake to start to engage. Or the check valve could be defective or clogged.
It can be very difficult to know what to do when the salesman states he has not seen the problem before. Check it out and see what you find.
ya im going to swap the valves this weekend and see what happens. the wheel turns freely though so its not enough pressure to engage the brake at all.
hes a friend and not really a salesman lol, he offered no question to replace the valve right away at his cost if i thought it was the problem... just wanted to ask around if anyone could think of any other reasons that might cause the pressure in the lines.
thanks for the help though ill post after i try the other valve(i hope to get to it this weekend)
