coolant catch can. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2006, 11:18 AM   #1 (permalink)
View iwannadie's Photo Gallery
coolant catch can.
so my coolant catch can has a pretty bad leak all along the bottom seam. i looked around and cant seem to find a place that sells oem ones.
horsepowerfreaks.com has a billet one, but im not sure if it would bolt up or not. its pretty cheap too, figure it would hold up better than the plastic oem one.
87 n/a at
iwannadie is offline   Reply With Quote
Old 06-18-2006, 12:05 PM   #2 (permalink)
JZ TWINS's Avatar
View JZ TWINS's Photo Gallery
What Supra do you have. I have one for a MKIV for sale cheap
JZ TWINS is offline   Reply With Quote
Old 06-18-2006, 01:55 PM   #3 (permalink)
i have an 87 n/a.
87 n/a at
Old 06-19-2006, 10:36 AM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
You can use that can, however it doesn't look like it is setup for the low coolant sensor. So... You'll have to deal with that and make sure it holds coolant. Other than that, it looks like every other generic catch can out there.
No, it won't bolt straight up, you'll have to figure another way to mount it.
Old 06-19-2006, 12:34 PM   #5 (permalink)
well the low coolant sensor isnt a big deal. is there any other replacements suggestions or any place you know of to get a New oem catch can? i dont want to get a used one and have it turn out to leak just like mine....
87 n/a at
Old 06-19-2006, 02:04 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
I've never heard of one leaking, either go buy one from toyota, or go to a junkyard and take a cup of water with ya
and really... IMO, the low coolant sensor is important.
Old 06-19-2006, 06:12 PM   #7 (permalink)
i figured id just check the coolant often enough and keep an eye on the temp gauge.. but i guess that could lead to serious problems pretty fast.
i might just try and glue the one i got. the leak is right on the bottom seam.
87 n/a at
Old 06-19-2006, 06:16 PM   #8 (permalink)
SuprAdam's Avatar
View SuprAdam's Photo Gallery
Just get a used one from a parts car.
I have never seen them leak either. They are plastic, don't see how they would develop a leak really unless they were dropped or excessive heat..weird.
Otherwise, JB weld! It will plug the leak.
- 1989 Supra turbo - r.i.p.
- 1986.5 Supra
--->GT40-82 powered 7MGTE, MSII V3.0 w/ VR/EDIS-6, 65 lb/hr inj.
SuprAdam is offline   Reply With Quote
Old 06-19-2006, 07:51 PM   #9 (permalink)
its weird, theres a seam along the bottom and right there its leaking in a few spots. not sure if its ever been dropped(not since ive owned it), but the leak has gotten worse in the last few months.
87 n/a at
Old 06-20-2006, 09:13 AM   #10 (permalink)
Got Hardass?
Jeeves's Avatar
You sure it's leaking and not oveflowing?
Old 06-20-2006, 12:57 PM   #11 (permalink)
ya i was under the car and saw the drips coming out from the seam. the can wasnt anywhere near full enough to overflow. there wasnt any coolant down the sides either, definitely coming from that seam on the bottom.
87 n/a at
Old 06-20-2006, 02:51 PM   #12 (permalink)
Got Hardass?
Jeeves's Avatar
Then I'd say JB Weld, or go pick one up.
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
Toyota Camry Coolant Problem vkbajoria Camry & Solara Lounge 14 03-30-2005 08:28 AM
Coolant level rainman Camry & Solara Lounge 16 02-02-2005 09:53 PM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-11-2004 11:03 PM
