Find max. boost w/o detonation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2003, 09:33 PM   #1 (permalink)
View SupaMuna's Photo Gallery
Question Find max. boost w/o detonation
How can you figure out your maximum boost presure w/o hitting detonation...is it even posible?
SupraManBoyDude
SupaMuna is offline   Reply With Quote
Old 03-17-2003, 11:53 AM   #2 (permalink)
View cdnsupra's Photo Gallery
it all depends on what modifications you install? each car/setup is different, and you need to install the monitoring guages to find out where your setup is on the grand scheme of things.
you can scan the internet groups to see what people run, but most guys stay around 12:1 for air fuel ratio, 12.5:1 if you are conservative, 940mv on the o-2 sesor and 920mv conservativly, and under 1000f on the egt guage, 800f conservatively.
a stock supra can be boosted to about 10psi, and still be very reliable.
with exhaust and air filter, but without added fuel or anything else, staying below 12psi will keep you running for a good long time.
wanna go faster than that? spend the money now to build a better motor/system, or end up with a junk pile a few short months.
stock is 5.75-6.25psi, so a jump to 12psi is quite a rush.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
