Swap Help...plzzz - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2006, 12:58 AM   #1 (permalink)
View vietn712's Photo Gallery
Swap Help...plzzz
i know this thread has been posted b4..but its hard to find it here on TN..but can anyone tell me what i need as in parts for a turbo swap..i have a 95 supra and i want to turbo swap it..if i buy part separately instead of buying the whole clips which is seemingly hard to find.i know i need the ENGINE, ECU, TRANNY, and WIRING HARNESS..do i need to buy a different DRIVESHALF too..one more question..can i put in a 6speed tranny into a 5speed engine..i mean is there a differance..thanks guys
vietn712 is offline   Reply With Quote
Old 08-10-2006, 09:36 AM   #2 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
What are you swapping from and to?
Old 08-10-2006, 10:41 PM   #3 (permalink)
from a N/A to a turbo..what do u recommend a 5spd or a 6spd.does all supra turbo engine have the same tranny bolt pattern?..which do u think would be a better route for me..the whole from clip or part separately..do u know where i can buy parts for the swap?thanks jeeves
Old 08-11-2006, 12:11 AM   #4 (permalink)
JZ TWINS's Avatar
View JZ TWINS's Photo Gallery
I have a friend who was N/a and he put a turbo kit on it. He also put a 6 speed matted to it. I think you will find out more info on the supra forums.
JZ TWINS is offline   Reply With Quote
Old 08-11-2006, 09:26 AM   #5 (permalink)
Got Hardass?
Jeeves's Avatar
Now, lemme think. Since you said 1994, we're going to assume it's a Mk4 Supra. Now, these are NOT my specialty, so take this all with a grain of salt.
IIRC You should not use the 2JZ-GE's W58 5 Speed Transmission for the 2JZ-GTE, nor would you want to. The w58 was NEVER built to hold the kind of power a 2JZ-GTE will put through it. You should use a Getrag V160 6 Speed transmission from a TT car. The W58 was beefed up slightly for the 2JZ-GE, but the 5 Speed R154 (Mk3 Supra) and the V160 (Mk4 Supra) are both far superior, and you can't use the R154 on the 2JZ.
For the swap, you'll probably need a whole front clip. Now, the 1994's weren't OBDII so, you've got a slight perk there. However, beyond that, I don't know much. Mk3 swaps are my gig.
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
tranny swap <<help plzzz bluedemon Archived Corolla threads 8 10-09-2004 12:24 AM
ATTN: speedemn - Yoshio Engine Swap Ratko Camry & Solara Lounge 4 12-28-2001 04:22 PM
