1988 manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2003, 05:50 PM   #1 (permalink)
kristoffer's Avatar
View kristoffer's Photo Gallery
Question 1988 manual
Im driving an 88 toyota supra and I dont have the manual and Im having problem. Theres this light that keeps turning on while Im driving its on your left hand side and it looks like a fluid its beside the temperature. Could anybody help me to figure this out and what can I do about it.
THanks,
KRistoffer
kristoffer is offline   Reply With Quote
Old 04-16-2003, 09:17 PM   #2 (permalink)
Repatriated POW
View supraturbo's Photo Gallery
If it's the same light I'm thinking about, then it's probably the coolant sensor light. The senor itself can be found on the underside of the coolant bottle. I think mine is completely fried, so I leave it disconnected, but you may want to get that checked out if you notice some overheating.(This is assuming you've checked your coolant levels)
BTW, if you want the manual, I've got a PDF copy somewhere here. I keep a printed version of that in my car. Come to a meet and check it.
(¯`·._.·[ s£ïm ]·._.·´¯)
-87 Supra Targa Turbo-
supraturbo is offline   Reply With Quote
Old 04-17-2003, 09:58 AM   #3 (permalink)
View cdnsupra's Photo Gallery
The yellow light to the left of the temp gauge is for the low coolant sensor. Some people refer to it as a bird cage, others a grille from a high end benz or bentley. It is supposed to look like a radiator.
What you need to do is add coolant to the overflow bottle. Do not go above the reccomended line. when the coolant in the engine gets hot, it forces itself into that bottle, and gets sucked back in when the engine cools. Over filling will just cause the coolant to be spewed out onto the road anyway.
if you find you are constantly filling this up, that is indicitive of a leak in the system. it can be anything from a pin hole leak on a hose somewhere, all the way to a BHG[BTW, I;m not trying to scare anybody here]
In addition, the TSRM is also on-line, and quite easy to navigate.
http://www.cygnusx1.net/supra/library/TSRM/index.html
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 02-25-2004, 07:32 PM   #4 (permalink)
View strong_man2000's Photo Gallery
light
your light means you are out of anti-freeze/water fluid. fix this fast or you will murder your engine! most likely its only going on around corners, when the liquid sways around... i think the light only serves this purpse, but it may also be for other low fluids
strong_man2000 is offline   Reply With Quote
Old 03-02-2004, 11:54 AM   #5 (permalink)
Re: light
the light only refers to the level of coolant in the overflow bottle, not in the rad, and not anywhere else in the engine. if it comes on during hard corners, or early in the morning, it is teetering on being low and not being low. it is a good time too add to it whenever it comes on, even for a second.
Please stick to facts when replying, not guessing, and scaring people. it is not helpfull.
Ben
