I am going to buy a 1985 supra for around $200 and decide to put a little more money in it.
They problem with the car is that the engine knocks and the ignition is torn out because someone stole it.
What do you think is causing the engine to knock and how much would it be to fix that?
and also how much do you think itll cost to fix the ignition?
without labor.
Thanks
Originally Posted by toyomoho
I take it the engine was knocking before the ignition was removed. What kind of knock and from what location on the engine? Is it a thud coming from the engine block? Could be a spun bearing. If so, this is a costly repair. What ignition parts are missing? You might look for a good used engine.
Actually The Car was stolen before it started knocking, well thats what he said.
Originally Posted by Doctor J
Obtain a good listenig device (mechanic's stetoscope) and probe the engine. the common problens on 5MGE motors are the noisy valve lifters (hydraulic). when oil changes were unfrequent, the lifters are getting contaminatedand producing the "clock ticking" sound.The remedy for this is the lifter service, which requres removal of the timing belt, cams with housings, cleaning the oil metering valve on the front of the head and cleaning/ replacement of the lifters. Also it is a very good idea to take off the cam housing covers and examine the cam lobes.If they are scored, chances are the engine was running low on oil.
Eliminate all possibilities of the knocks made by external components.The engine with heavy dull knock similar to the one produced by the sledge hiting the concrete is a sure candidate to replacement. According to the rebuilders opinion, these engines are very hard to rebuild in the shop conditon.
hmm, cleaning the engine? that seems hard???
