1989 Suprra 7MGE Head Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2006, 03:39 PM   #1 (permalink)
View rayk5799's Photo Gallery
Hello Everyone...................
I am having some issues with my Supra and it recently started to pour out white steam, which is a head gasket indicator but I replaced the head gasket about year and a half ago.
Well, I thought I should do it again but after having the head resurfaced and pressure tested, I installed the new toyota dealer head gasket and replaced all the head bolts with original toyota along with the fuel injection seals.
Started it up alittle while ago and poof........white steam again.
I checked the block deck for flatness and it was good. Sanded the surface using sand paper and a flat piece of metal.
I am assuming that the block MUST have a crack in it or am I wrong??
Any suggestions would be great.
Ray
rayk5799 is offline   Reply With Quote
Old 09-27-2006, 10:00 PM   #2 (permalink)
5M-GE
repinS's Avatar
View repinS's Photo Gallery
To what amount did you torque the head bolts to?
85 Cressida // RIP 11/2003
95 Pontiac Bonneville SSEi | 3800 SC | 225hp/275lb-ft
repinS is offline   Reply With Quote
Old 09-27-2006, 10:03 PM   #3 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
Have you done the basics: rad cap, thermostat etc?
bgrieger is online now   Reply With Quote
Old 09-28-2006, 12:12 AM   #4 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
Probably a crack in the head. Clean it up and inspect it.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 09-28-2006, 08:07 AM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $263690
View Doctor J's Photo Gallery
What type of machine work have been done to the head?
Use of the sandpaer to clean the block sealing surface is not recommended.
Doctor J is offline   Reply With Quote
Old 09-28-2006, 09:46 AM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Sand Paper is a horrrribleeee thing for the smoothness a Head Gasket needs. Serious. That's a BAD thing,
Old 09-28-2006, 01:00 PM   #7 (permalink)
TcmaBoy's Avatar
I sduppose it depends on what grit, and how you did it. If you used a super fine grit like 800 or 1K with some oil it will be ok. The oil will cut the grit even further and you will end up with a rather nice smooth surface. If you used something aggresive like 120 then that will score up the head pretty bad.
Old 09-28-2006, 01:02 PM   #8 (permalink)
I torqued the head to 72 ft lbs. I checked all the hoses, theromstat and sensors but nothing. The sand paper that I used was 400 grit so I think its mild enough but what to do instead of sand paper to clean the deck of the block??
Old 09-28-2006, 01:10 PM   #9 (permalink)
I had the head resurfaced and pressure tested. The valves were recently done as the head gasket was previously done about a year ago.
Old 09-28-2006, 02:37 PM   #10 (permalink)
Doctor J's Avatar
For cleaning of the block surface, the blade type scraper with beveled edges is a best choice.The head must be milled to 30 Ra microinch. (this will leave flat surface with faint circular marks. Unfortunately, many shops just put the head on the belt sander (especially for one-time customer). Such machining leaves mattle dull finish. The most common reason for shops not to mill the head is the old inaccurate machines such as late 70s Storm-vulcan.
Old 09-28-2006, 07:55 PM   #11 (permalink)
What is the best waty other than removing the engine to see if the block is cracked??
Old 09-29-2006, 07:52 AM   #12 (permalink)
bgrieger's Avatar
Either the engine comes out or the head comes off. When looking for this kind of problem those are the only choices. Taking the engine out at once makes it easier in case you find there is a problem...no need to reinstall the head just to pull it again...
With the head off you can have it inspected by your machinist for problems and to straighten and deck as required. Then you clean the deck of the block. If you are using a Toyota composite gasket, sealing is rarely a problem unless there is visable damage to the block. Scrape with a plastic putty knife and gasket removal compound, making sure nothing gets in the cylinder bores. Wipe repeatedly with a cloth and acetone or other non water based cleaner until it starts to wipe clean (aka doesn't pick up any more dirt...white rags are a lifesaver for this).
You could use a UV sensitive dye and a black light from NAPA to look for minor cracks and imperfections on the block surface, but really a fingernail test and visual inspection up close will let you know if there's a problem in the head gasket mating surfaces. Marks from the fire rings that your nail catches on are bad, those you only feel going under are usually alright, though not always. It is a less than scientific test, but I've used it many times over the years with complete success. You can also inspect the gasket prior to removing it for deformation in the fire rings to see if it is just a blown gasket too. BTW, this testing applies only if you're installing a composite gasket after...Don't bother trying a metal head gasket if you're not getting the block and head machined to a low Ra count as Dr J mentioned above.
Old 09-29-2006, 10:21 AM   #13 (permalink)
Doctor J's Avatar
The common reason for block to crack, is when the bolt holes have left-over oil or coolant in there.
Older Supra heads used to develop small cracks between intake and exhaust valve seats, but these cracks are the harmless.
Please HELP!! '85 Supra charging problem......an advanced problem... sbarc Hardcore Tech and Competition 5 07-14-2005 07:10 PM
odd vibration problem niju321 Camry & Solara Lounge 3 07-07-2005 12:15 PM
Engine Problem!!! Mk1, 1989 help!!! mikeym MR2 Forum 5 04-22-2005 01:35 PM
problem with headers mostly head gasket ikonppl Archived Corolla threads 13 01-19-2004 03:37 PM
head light problem rcj93cam Camry & Solara Lounge 5 04-01-2003 09:23 PM
