supra tech questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2003, 05:09 PM   #1 (permalink)
View kevin's Photo Gallery
I JUST BOUGHT AN 87 SUPRA(7M-GTE)WITH LOW MILES.THE QUESTIONS I HAVE ON IT ARE,WHAT IS THE VOLTAGE RANGE OF THE TPS AT IDLE AND WIDE OPEN THROTTLE?THE EASIEST WAY TO ADJUST THE WASTE GATE AND MAX. BOOST FOR STOCK HEADGASKET?ALSO WHAT KIND OF FUEL PRESSURE SHOULD I BE GETTING WITH THE STOCK PUMP?IF ANYONE CAN HELP I WOULD APPRECIATE IT! THANKS
kevin is offline   Reply With Quote
Old 04-25-2003, 08:26 AM   #2 (permalink)
View cdnsupra's Photo Gallery
First, you can get info from an online TSRM at this site. It has the complete toyota Service and repair manual all digitized.
http://www.cygnusx1.net/supra/library/TSRM/index.html
to test the tps, you can use the test 2 on this page measuring from the ecu end:
http://www.cygnusx1.net/supra/librar...fi/FI_032.html
It is also possible to do the test at the TPS itself:
http://www.cygnusx1.net/supra/librar...fi/FI_036.html
the easiest way to adjust the wastegate is to add 2 washers to the wastegate bolts to push the actuator away from the turbo. depending on the washers used, you can go up to 12psi before running out of stock fuel.
max boost for stock head gaket? that is a tough question. How long do you want it to last? the more boost you run, the shorter it will last. I run 10psi, and mine has lasted 5-6 years with no problem. people who run 12 or more boost usually end up breaking something, and sometimes that is the head gasket that goes.
stock fuel pressures are posted on the mailing list at supras.com quite often. they may also be on a FAQ page there. If not talk to Arlene in Oklahoma or Dave Henry from Minieapolis from that list. I think it should be around 35psi at idle. it will drop as you increase boost and rpms because of the fuel being used.
Hope that helps.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
