1987 supra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2006, 12:21 PM   #1 (permalink)
View gsantos79's Photo Gallery
1987 supra
just got a 1987 supra non turbo.. wanna do a swap.. can anyone tell which turbo motor goes rite in with no mods.. 1jz or 2jz? use to be a honda guy.. dont really no too much about toyotas.. thanks guys
gsantos79 is offline   Reply With Quote
Old 10-27-2006, 03:15 PM   #2 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
The answer is the motor that is in it now. Any motor swap will involve changing motor monts, the wire harness, ECU, etc. There is no such thing as a "bolt in" swap. In the case of an 87 the entire front subframe has to be changed out to accomodate anything other than a 7M.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline   Reply With Quote
Old 10-28-2006, 08:28 AM   #3 (permalink)
USA
thanks for the info.. wat does a full swap cost? n also can i use the 5 speed trans from my n/a motor on the 1jz?
Old 10-28-2006, 12:46 PM   #4 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Not without tryin' to adapt it somehow. Even then, You shouldn't. W58's are worthless above 300tq.
A full swap is usually, 3,000-5,000, depending on where you get your front cut (you can't just buy the motor, you need the front half of those donor cars) and how much labor/extra parts it takes to get it all in.
Old 10-28-2006, 01:16 PM   #5 (permalink)
TcmaBoy's Avatar
I use a R-154. The 1JZ came equipped with it, so there is a correct bell housing available. No adapters needed. The 1JZ clutch is the same clutch used with the 7MGTE making them easy to find.
Old 10-29-2006, 08:01 AM   #6 (permalink)
is a 7mgte any good?
Old 10-29-2006, 08:03 AM   #7 (permalink)
thanks for the help man.. also can someone give me the whole breakdown for wat i need for the swap..
Old 10-29-2006, 11:10 AM   #8 (permalink)
TcmaBoy's Avatar
With a little work its a good motor.
Old 10-29-2006, 01:15 PM   #9 (permalink)
wat kind of work? turbo upgade?
Old 10-29-2006, 04:58 PM   #10 (permalink)
TcmaBoy's Avatar
Nope, just needs a MHG.
Old 10-29-2006, 10:36 PM   #11 (permalink)
Got Hardass?
Jeeves's Avatar
...which also includes machining the head and block.
Old 10-30-2006, 08:39 AM   #12 (permalink)
ya thanks.. i think im gonna go with the 7mgte route.. the swap sound a hell of a lot easier then the 1jz.. still loooking for a motor.. ill keep u guys updated.. thanks again..
1987 Toyota Supra Turbo EBAY JOSHKENNEDY Vehicles 1 02-20-2006 06:24 AM
1987 supra turbo value kgizzle1 Supra Forum 2 10-04-2005 08:12 PM
For sale: 1987 tuned n/a Supra Drasord Supra Forum 5 08-16-2005 07:08 PM
PLease help 1987 supra 1987ToyotaSupra Supra Forum 6 05-05-2005 01:16 AM
1987 toyota supra xX-nightmare-Xx Hardcore Tech and Competition 4 08-28-2004 09:32 AM
