With the plans you have that power level is entirely possible. You can use a stock toyota block, rods and pistons with the metal gasket and drive it till the cows come home if you keep the fuel tuned properly. Let me recommend you also get the head ported and polished to improve flow. At the top end, that is where it needs the help. Cams are optional, but will see benefits in that range. You won't be doing it on a factory turbo though. Expect to get a new turbo, I recommend the GT35R for great spool on the street and more than enough top end. Electronics are going to be needed, and at that level, a piggyback like the MAFT-PRO would do the trick, or perhaps standalone if you have the finances. Stock fuel is also going to be an issue, so an upgraded pump is in order. A walboro in tank should do you, but an external is also a decent choice at that stage of the game. Gives you a little more room to grow that way too.
