In order of your questions:
1. Of course you can put any gasket you want on and torque it down.
2 You could also try it.
Now for the long answers. Some have tried this and succeeded, but not very many. The head needs a machine shop visit with almost certainty. The block may be alright, but you again take your chances. Given it sounds like you've never done this before, I'm not trying to belittle you, but you likely won't be able to tell "should do" from "you're F---ed for even trying it".
While the head would have to go to the machinist, using a stock gasket will usually seal in all but the worst blocks. Again, you have to know what you are looking for (pitting corrosion and fire ring impressions), but they are far more forgiving.
Now, if the head gasket is not leaking, just run it that way until you are ready to do it properly. Don't even bother with a metal gasket on unmilled parts. You'll just have to replace it in short order.
