if it is/was a gas line, you would be empty wihtin 10 minutes, as the fuel line is under about 30psi pressure, and will empty the tank rather quickly if there is any big leak.
if it is just a smell of gas, then maybe it is the canister, or a vacumm line going to or coming from it is cracked.
you could also have a loose fuel rail letting gas out by the injector o-rings.
you could also have a clogged air filter, and the engine is running so rich, you can smell the gas.
if you don't know much about cars, you should go to a mechanic. gas leaks are not something you wanna "fuel" around with. lol
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
