Supra + California Smog - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2006, 09:52 PM   #1 (permalink)
View jerrry1234's Photo Gallery
Unhappy Supra + California Smog
Help please.
I recently purchased an 88 Supra Turbo with a broken timing belt. Did the necessary repairs and the car runs fine, That is until it came to the CA Smog inspection. I think part of the problem might be that the car was broken for 2 years.
Anyway, the results of the smog inspection are as follow:
15mph HC (PPM) 178 (Max allowable 106) CO% 1.07 (max 0.70)
25mph HC 194 ( Max 81) CO% 1.27 (max 0.57)
NO passed inspection with 32ppm@15mph and 64ppm@25mph
Appreciate any advice available.
jerrry1234 is offline   Reply With Quote
Old 11-15-2006, 02:31 AM   #2 (permalink)
View toyomoho's Photo Gallery
The link below has some causes of high HC emissions. Might do a tune up.
http://www.aa1car.com/library/2000/ic60032.htm
Old 11-15-2006, 08:14 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $263690
View Doctor J's Photo Gallery
With the car that have been sitting for two years, the fuel system deposits could also contribute to the higher HC/CO emissions. When in 1991 I first started my 79Supra after 6 month sitting in the storage yard, the soot came out from exhaust.
What are the CO2, NOx and O2 numbers ?
Doctor J is offline   Reply With Quote
Old 11-15-2006, 10:31 AM   #4 (permalink)
Thanks for the replies.
The other readings you asked about are:
15 mph CO2 13.90 O2 .38 NO 32
25 mph CO2 13.69 O2 .35 NO 64
Any ideas appreciated.
Old 11-15-2006, 12:21 PM   #5 (permalink)
Doctor J's Avatar
From the latter readings it looks like the engine runs slightly rich;
Sometimes it could be due to the old oxygen sensor, defective fuel pressure up system (no vacuum is supplied to the fuel pressure regulator) or damaged connectors on the coolant thermosensor THW.
Old 11-15-2006, 03:07 PM   #6 (permalink)
Got Hardass?
Jeeves's Avatar
View Jeeves's Photo Gallery
Catalytic converter/timing can also pick up some of those issues.
Getting a BPU Supra TT from another State and brining into California? CrazySupra88 Supra Forum 4 08-07-2006 04:17 PM
California Smog Check touringcamry General Discussion 4 01-16-2006 09:47 AM
California: new smog rules began on 1/1/05 Deuce General Discussion 4 05-04-2005 01:32 PM
California smog for '03 V6 RF951 5th & 6th Generation (2002-2006 & 2007-2011) 0 09-20-2004 01:14 PM
California Smog Piddy MR2 Forum 2 03-17-2004 12:35 PM
