A local rad shop has the block testor, and they do the test for free, hoping they will get a rad deal out of it. i have given them business both before and after they did the test. there are several types of block(BHG) testors on the market. try to find one and have this test done. maybe even your mechanic has one.
in reality, i have only seen 3 things that push coolant into the reservior, and eventually overflow.
1. the reservior is filled too high, so it overflows until the nominal level gets back to the fill line.
2. the rad cap is faulty, and is letting more coolant past when it shouldn't.
3. BHG is introiducing combustion gasses into the coolant passages, which raises the coolant pressure, and forces the rest out to the reservior.
Do you see the rad light come on? it is the far left gauge, and looks something like a bird cage?
can you smell coolant when standing around the car, either front or back after driving her on the hiway?
do you see oil scum deposits in the reservior bottle?
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
