turbo problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2006, 08:59 PM   #1 (permalink)
95 Toyota Pickup
View Sharpe88's Photo Gallery
Canada turbo problems
88 supra with a 3L seems like the turbo is losing pressure, spark plugs fine, doesnt seems to be losing oil, any ideas??? and does anybody know the wastegate specs
Sharpe88 is offline   Reply With Quote
Old 11-25-2006, 10:50 PM   #2 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $309150
View bgrieger's Photo Gallery
should be about 6psi pressure. Check hoses amd clamps first if you see less or suspect a leak.
bgrieger is online now   Reply With Quote
Old 11-26-2006, 04:17 AM   #3 (permalink)
View Maximuscr31's Photo Gallery
It always helps to pressurize the intake system starting at the turbo inlet. If there is a leak it will be well known. do it with the car off and have someone watch your boost guage. If pressure drops fast or doesn't build you got a leak, if it hold solid and takes 45 seconds or more to fall back down to 0 then your good. Sounds like a possible boost leak though. Remember not all leaks are visible or occur at low psi.
Maximuscr31 is offline   Reply With Quote
Old 11-27-2006, 09:09 PM   #4 (permalink)
95 Toyota Pickup
Canada
thanks for your help dude
Turbo Problems FightClubMunkey 1st Generation (2003-2008) 2 01-28-2004 08:42 PM
