turbo reads zero... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2003, 01:06 AM   #1 (permalink)
View poodlepower's Photo Gallery
turbo reads zero...
i think i have a clugged turbo... the gauge goes to zero when i turn on the car but when the turbo kicks in (+3000rpms) all i hear is whistling from the hood and the needle doesn't budge from zero.
thanks for the helps
poodlepower is offline   Reply With Quote
Old 05-24-2003, 04:30 PM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
Its time to replace that sucker ..
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 05-25-2003, 08:31 AM   #3 (permalink)
View suprat89's Photo Gallery
Go to the online Supra manual at www.supras.com. It is under TSRPIII, and go throught the Turbo troubleshooting section. This might help you.
Good luck
suprat89 is offline   Reply With Quote
Old 05-28-2003, 08:39 AM   #4 (permalink)
View cdnsupra's Photo Gallery
in my experience, whistling sounds under boost can also be attributed to loose exhaust manifold nuts. check to see if they are tight or not.
if so, it is best to buy new studs and nuts, and tighten them to the 15-20ft-lbs as in the manual. they are steel studs into the alluminum head, so they will not be able to take lots of torque before just pulling out.
that would be my first place to look.
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 08-25-2003, 11:02 AM   #5 (permalink)
View celicaship1211's Photo Gallery
Lightbulb supra turbo
im not to big into supras yet, specially not the older ones. but i know that my friend had that same problem with his 89' ford probe GT. and like that guy said, it was a loose exhaust manifold nut. so you might want to check that out.
wang
celicaship1211 is offline   Reply With Quote
