idle surge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2003, 04:27 PM   #1 (permalink)
View kevin's Photo Gallery
idle surge
when i start my supra the idle surges between 1200 - 2200 rpm this all started suddenly and it continues to do it even when warm. i've cleaned the maf and checked the vacuum lines,everything seems to be in working order.what else can i check?thanks
kevin is offline   Reply With Quote
Old 05-26-2003, 08:46 PM   #2 (permalink)
View PREDTR's Photo Gallery
Could be your TPS. Make sure the voltage is within spec on the TPS.
PREDTR is offline   Reply With Quote
Old 05-27-2003, 09:06 PM   #3 (permalink)
View suprat89's Photo Gallery
It could be a Intake gasket leak also!
suprat89 is offline   Reply With Quote
Old 05-27-2003, 09:15 PM   #4 (permalink)
found out the tps was bad.thanks for the help
Old 05-28-2003, 08:40 AM   #5 (permalink)
View cdnsupra's Photo Gallery
good call predtr!
i guess this is one thing we did learn from alex way back when we were just noobies!
Ben
CdnSupra from Hamilton
91T, stage 3+[87T has been retired]
cdnsupra is offline   Reply With Quote
Old 05-28-2003, 08:46 AM   #6 (permalink)
Originally posted by cdnsupra
good call predtr!
no kidding cdnsupra,
i think i have gone through about 3 of these tps's. if all else fails, blame it on the tps
Old 05-29-2003, 04:03 AM   #7 (permalink)
View Teraka's Photo Gallery
Noob question, how do you check the TPS? (I'm having the same problem w/ my na)
Teraka is offline   Reply With Quote
Old 05-31-2003, 08:46 AM   #8 (permalink)
i changed the tps after i scanned the engine codes.also i just took it off and checked the spring action of the lever.
